Aller au contenu principal
Canon PowerShot G7X Flash Replacement
Kyle Pellham
Kyle Pellham et 3 autres contributeurs
Dernière mise à jour le June 15, 2018
15 - 20 minutes
Modérée
This guide will help you replace the flash for your camera. Caution should be used because a capacitor is attached to the flash which may cause harm if handled carelessly.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Canon PowerShot G7X Flash Replacement, Dial: étape 1, image 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Flash Replacement: étape 2, image 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Flash Replacement: étape 3, image 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Flash Replacement: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Flash Replacement: étape 5, image 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Flash Replacement: étape 6, image 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Flash Replacement: étape 7, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 7, image 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Flash Replacement, Flash: étape 8, image 1 de 2 Canon PowerShot G7X Flash Replacement, Flash: étape 8, image 2 de 2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Flash Replacement: étape 9, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 9, image 2 de 2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Flash Replacement: étape 10, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 10, image 2 de 2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Flash Replacement: étape 11, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 11, image 2 de 2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Flash Replacement: étape 12, image 1 de 1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Flash Replacement: étape 13, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 13, image 2 de 2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Flash Replacement: étape 14, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 14, image 2 de 2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Flash Replacement: étape 15, image 1 de 2 Canon PowerShot G7X Flash Replacement: étape 15, image 2 de 2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
Kyle Pellham
Membre depuis le 04/09/18
420 Réputation
2 tutoriels rédigés
Un commentaire
Hi,
great guide, thanks!. Where can I buy the flash?
Best
david olivelli - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 25
30 derniers jours : 63
Total : 2,980
