Aller au contenu principal
Canon PowerShot S100 GPS Board Replacement
Ricky
Ricky et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 20 minutes
Modérée
This camera has a GPS that tracks where pictures have been taken. If the GPS board malfunctions, it can be removed and replaced.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot S100 GPS Board Replacement, Outer Case: étape 1, image 1 de 3 Canon PowerShot S100 GPS Board Replacement, Outer Case: étape 1, image 2 de 3 Canon PowerShot S100 GPS Board Replacement, Outer Case: étape 1, image 3 de 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 GPS Board Replacement: étape 2, image 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 GPS Board Replacement: étape 3, image 1 de 3 Canon PowerShot S100 GPS Board Replacement: étape 3, image 2 de 3 Canon PowerShot S100 GPS Board Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 GPS Board Replacement, Top Panel: étape 4, image 1 de 1
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 GPS Board Replacement: étape 5, image 1 de 2 Canon PowerShot S100 GPS Board Replacement: étape 5, image 2 de 2
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 GPS Board Replacement: étape 6, image 1 de 2 Canon PowerShot S100 GPS Board Replacement: étape 6, image 2 de 2
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
  7. Canon PowerShot S100 GPS Board Replacement, GPS Board: étape 7, image 1 de 1
    • Turn the camera over so that the camera lens is facing you.
    • Using the spudger, detach the ribbon cable that is connecting the GPS tracker to the motherboard.
  8. Canon PowerShot S100 GPS Board Replacement: étape 8, image 1 de 2 Canon PowerShot S100 GPS Board Replacement: étape 8, image 2 de 2
    • Turn the camera over so that the top edge is facing you, and the lens is away from you.
    • Gently lift the folded ribbon cable piece off of the camera body.
    • The folded ribbon cable piece is glued onto the camera, so removing it will require minimal force.
  9. Canon PowerShot S100 GPS Board Replacement: étape 9, image 1 de 2 Canon PowerShot S100 GPS Board Replacement: étape 9, image 2 de 2
    • Lift to expose the Phillips #00 screw located beneath it.
    • Unscrew the 2 screws (4.1mm, 1.8mm, both Phillips #00) connecting the GPS tracker to the camera.
    • Remove the GPS tracker by gently lifting it off of the pin that holds it to the top of the camera.
2 autres ont terminé cette réparation.
Ricky
Membre depuis le 02/23/15
968 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 1,159
