Canon PowerShot S400 SD Card Slot Replacement
Introduction
Passez à l'étape 1This guide provides instructions for the SD card replacement of The Canon PowerShot S400. Whether your preference is to archive the SD card for memories or switch it out for a new one, this purposeful guide walks you through the replacement process step by step. Beginning with which screwdriver to use through removing the memory card, the maximum replacement process is estimated to be 35 minutes. No prior knowledge is necessary to understand the instructions for the SD card replacement guide.
Ce dont vous avez besoin
Remove the 4.75mm screw located in the top right corner of the backside of the camera.
Remove the four 4.75mm screws located on the bottom of the camera.
