Aller au contenu principal
Canon PowerShot S400 Shutter Button Assembly Replacement
Ross Bryan
Ross Bryan et 5 autres contributeurs
Dernière mise à jour le January 28, 2014
15 minutes
Modérée
This guide provides instructions on how to replace the shutter button assembly on the Canon PowerShot S400.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: étape 1, image 1 de 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: étape 1, image 2 de 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 1 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 2 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 3 de 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 1 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 2 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 3 de 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 4, image 1 de 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Ross Bryan
Membre depuis le 01/21/11
374 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-19, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 2,756
