Aller au contenu principal
Canon PowerShot S50 Right Motherboard Replacement
Jacob
Jacob et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
20 - 30 minutes
Modérée
Tutoriel vedette
Use this guide to remove the motherboard on the right side of the camera.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Canon PowerShot S50 Right Motherboard Replacement, Battery: étape 1, image 1 de 2 Canon PowerShot S50 Right Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Canon PowerShot S50 Right Motherboard Replacement: étape 2, image 1 de 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Canon PowerShot S50 Right Motherboard Replacement: étape 3, image 1 de 2 Canon PowerShot S50 Right Motherboard Replacement: étape 3, image 2 de 2
    • Holding the edges, slide out the battery.
  4. Canon PowerShot S50 Right Motherboard Replacement, Front Panel/Battery Door: étape 4, image 1 de 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Canon PowerShot S50 Right Motherboard Replacement: étape 5, image 1 de 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Canon PowerShot S50 Right Motherboard Replacement: étape 6, image 1 de 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Canon PowerShot S50 Right Motherboard Replacement: étape 7, image 1 de 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Canon PowerShot S50 Right Motherboard Replacement: étape 8, image 1 de 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Canon PowerShot S50 Right Motherboard Replacement: étape 9, image 1 de 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Canon PowerShot S50 Right Motherboard Replacement: étape 10, image 1 de 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Canon PowerShot S50 Right Motherboard Replacement: étape 11, image 1 de 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Canon PowerShot S50 Right Motherboard Replacement: étape 12, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Canon PowerShot S50 Right Motherboard Replacement: étape 13, image 1 de 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Canon PowerShot S50 Right Motherboard Replacement, Right Motherboard: étape 14, image 1 de 1
    • Disconnect the two plastic ribbons on the lower half of the right motherboard.
    • NOTE: You will have to lift up the brown plastic piece in order to pull out the second ribbon wire.
  15. Canon PowerShot S50 Right Motherboard Replacement: étape 15, image 1 de 1
    • Remove the two 3.4mm screws on the right motherboard.
  16. Canon PowerShot S50 Right Motherboard Replacement: étape 16, image 1 de 1
    • Disconnect the two wired plugs below the flash.
  17. Canon PowerShot S50 Right Motherboard Replacement: étape 17, image 1 de 1
    • Disconnect the wired plug at the bottom of the right motherboard.
  18. Canon PowerShot S50 Right Motherboard Replacement: étape 18, image 1 de 1
    • Use a pair of tweezers to pull the right motherboard away from the main body of the camera.
2 autres ont terminé cette réparation.
Jacob
Membre depuis le 03/29/12
13 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-34, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 1,188
