Aller au contenu principal
Canon PowerShot S500 Front and Rear Casing  Replacement
Nathan Balcom
Nathan Balcom et 6 autres contributeurs
Dernière mise à jour le February 19, 2025
10 minutes
Très facile
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : étape 1, image 1 de 2 Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : étape 1, image 2 de 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: étape 2, image 1 de 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: étape 3, image 1 de 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: étape 4, image 1 de 2 Canon PowerShot S500 Front and Rear Casing  Replacement: étape 4, image 2 de 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: étape 5, image 1 de 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Ligne d'arrivée
Nathan Balcom
Membre depuis le 01/21/10
102 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 16-28, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 10
Total : 1,674
