Aller au contenu principal
Canon PowerShot SD1100 IS Top Button Assembly Replacement
Wyatt Chan
Wyatt Chan et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 20 minutes
Modérée
In this guide you will learn to remove the top button assembly, which can be replaced if damaged or filled with debris.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: étape 1, image 1 de 2 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: étape 1, image 2 de 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 2, image 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 2, image 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 2, image 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 3, image 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 3, image 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 3, image 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 4, image 1 de 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: étape 5, image 1 de 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 6, image 1 de 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: étape 8, image 1 de 1
    • The shutter button assembly should now be removed.
Wyatt Chan
Membre depuis le 01/05/11
235 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 2,185
