Aller au contenu principal
Canon PowerShot SD1200 IS Motherboard
Jeff Casper
Jeff Casper et 4 autres contributeurs
Dernière mise à jour le December 25, 2016
Aucune estimation
Modérée
Découpez pour améliorer
Use this guide to access the motherboard to reseat connections on the motherboard or to remove the motherboard for replacement.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: étape 1, image 1 de 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: étape 2, image 1 de 3 Canon PowerShot SD1200 IS Motherboard: étape 2, image 2 de 3 Canon PowerShot SD1200 IS Motherboard: étape 2, image 3 de 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: étape 3, image 1 de 2 Canon PowerShot SD1200 IS Motherboard: étape 3, image 2 de 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: étape 4, image 1 de 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: étape 5, image 1 de 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: étape 6, image 1 de 2 Canon PowerShot SD1200 IS Motherboard: étape 6, image 2 de 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: étape 7, image 1 de 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: étape 8, image 1 de 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: étape 9, image 1 de 1
    • Lift out the motherboard.
Jeff Casper
Membre depuis le 09/15/16
860 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 17-5, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 483
