Aller au contenu principal
Canon PowerShot SD1300 IS Lens Replacement
Clayton
Clayton et 4 autres contributeurs
Dernière mise à jour le February 23, 2024
10 - 25 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
This guide will show you how to properly replace a faulty lens on your Canon PowerShot SD1300 IS.
Ce dont vous avez besoin
Outils
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: étape 1, image 1 de 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: étape 1, image 2 de 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: étape 1, image 3 de 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: étape 2, image 1 de 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: étape 3, image 1 de 1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: étape 4, image 1 de 1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
2 autres ont terminé cette réparation.
Clayton
Membre depuis le 03/20/17
560 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S13-G1, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S13-G1, Bennett Spring 2017
TTU-BENNETT-S17S13G1
5 membres
5 tutoriels rédigés
Un commentaire
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 37
Total : 1,545
