Aller au contenu principal
Canon PowerShot SD500 Digital ELPH LCD Replacement
Taylor Shields
Taylor Shields et 4 autres contributeurs
Dernière mise à jour le June 8, 2017
5 minutes
Modérée
Many companies sell only LCD screens, not complete screen assemblies. When replacing your broken LCD screen, it may be necessary to tear down the screen even further.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SD500 Digital ELPH LCD Replacement, Battery: étape 1, image 1 de 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 2, image 1 de 2 Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 2, image 2 de 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: étape 3, image 1 de 2 Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: étape 3, image 2 de 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 4, image 1 de 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 5, image 1 de 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 6, image 1 de 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 7, image 1 de 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 8, image 1 de 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 9, image 1 de 2 Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 9, image 2 de 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH LCD Replacement, Button Contact Panel: étape 10, image 1 de 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 11, image 1 de 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 12, image 1 de 3 Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 12, image 2 de 3 Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 12, image 3 de 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH LCD Replacement, LCD: étape 13, image 1 de 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 14, image 1 de 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 15, image 1 de 2 Canon PowerShot SD500 Digital ELPH LCD Replacement: étape 15, image 2 de 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
3 autres ont terminé cette réparation.
Taylor Shields
Membre depuis le 10/13/14
846 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 2-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 766
