Aller au contenu principal
Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Battery: étape 1, image 1 de 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 2, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 2, image 2 de 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: étape 3, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: étape 3, image 2 de 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 4, image 1 de 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 5, image 1 de 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 6, image 1 de 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 7, image 1 de 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 8, image 1 de 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 9, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 9, image 2 de 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Wrist Strap Mount: étape 10, image 1 de 1
    • Unscrew two Phillips screws using a #00 Phillips screwdriver from front cover of the camera.
  11. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 1 de 3 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 2 de 3 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 3 de 3
    • Remove plastic cover from front side of camera.
    • Remove and pull away wrist strap mount from the front side of the camera.
Kimberly Saeger
Membre depuis le 10/13/14
101 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 2-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 234
