Aller au contenu principal
Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement
Kimberly Saeger
Kimberly Saeger et 3 autres contributeurs
Dernière mise à jour le January 10, 2015
5 minutes
Facile
The wrist strap mount is the piece that the wrist strap wraps around. The wrist strap allows the user to conveniently carry around the Powershot SD500 Digital ELPH. If broken, the camera will no longer have a wrist strap.
Ce dont vous avez besoin
Outils
  1. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Battery: étape 1, image 1 de 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 2, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 2, image 2 de 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: étape 3, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: étape 3, image 2 de 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 4, image 1 de 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 5, image 1 de 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 6, image 1 de 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 7, image 1 de 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 8, image 1 de 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 9, image 1 de 2 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: étape 9, image 2 de 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Wrist Strap Mount: étape 10, image 1 de 1
    • Unscrew two Phillips screws using a #00 Phillips screwdriver from front cover of the camera.
  11. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 1 de 3 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 2 de 3 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: étape 11, image 3 de 3
    • Remove plastic cover from front side of camera.
    • Remove and pull away wrist strap mount from the front side of the camera.
Kimberly Saeger
Membre depuis le 10/13/14
101 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 2-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 259
