Aller au contenu principal
Canon PowerShot SD850 IS Battery Replacement
Peter Tran
Peter Tran et 8 autres contributeurs
Dernière mise à jour le June 29, 2021
2 - 3 minutes
Très facile
Images incohérentes
The Canon PowerShot SD850 IS digital camera uses rechargeable batteries that you will occasionally have to remove. You can tell that your battery needs charging when the camera fails to turn on or displays a low battery indicator onscreen. Fortunately, you can easily get your camera running again. This guide explains how to remove or install the battery of your Canon PowerShot SD850 IS in two simple steps.
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: étape 1, image 1 de 3 Canon PowerShot SD850 IS Battery Replacement, Battery: étape 1, image 2 de 3 Canon PowerShot SD850 IS Battery Replacement, Battery: étape 1, image 3 de 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Battery Replacement: étape 2, image 1 de 2 Canon PowerShot SD850 IS Battery Replacement: étape 2, image 2 de 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
To reassemble your device, follow thee instructions in reverse order.
Peter Tran
Membre depuis le 10/06/10
225 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-7, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 11
Total : 3,074
