Introduction
Use this guide to remove a broken flash unit from your Canon PowerShot SD850 IS.
Outils
Pièces
Aucune pièce spécifiée.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
Remove the 1.85 mm #00 Phillips located on the left side of the camera.
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
