Introduction
Use this repair guide to replace a broken LCD screen on your Canon PowerShot SD850 IS.
Outils
Pièces
Aucune pièce spécifiée.
Using your fingernail, slide the light gray tab towards edge of camera.
Slide the light gray door and pull up to open the door.
Both Battery and Memory Card slots should be visible.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
