Canon PowerShot SX150 IS Buttons Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the buttons on your Canon Powershot SX150 IS. You can use this guide if any of your buttons no longer work.
Ce dont vous avez besoin
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
Outil utilisé dans cette étape :Tweezers$4.99
Once the back plate is removed. Locate the buttons to the right of the screen.
Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
After lifting the tabs the buttons should come right off, then replace with the new button.
Un commentaire
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
