Canon PowerShot SX280 HS Back Button Panel Replacement
Ce dont vous avez besoin
Outils
Turning the camera off
Removing the battery to reduce the risk of shock
Once the battery is removed, you can begin to take the outer screws out. Removing these will allow you to remove the camera case. It will require a #00 phillips screwdriver.
Be sure to be careful when removing these screws as they are easy to lose. Be gentle as well, as they are made of weak material and can strip easily.
