Canon PowerShot SX50 HS Rear Case Replacement
Introduction
Passez à l'étape 1Remove the back encasement of the Canon PowerShot SX50 HS.
Ce dont vous avez besoin
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Outil utilisé dans cette étape :Tweezers$4.99
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
3 autres ont terminé cette réparation.
