Aller au contenu principal
Canon PowerShot SX600 HS Main Board Processor Replacement
Scott Childress
Scott Childress et un autre contributeur
Dernière mise à jour le May 15, 2017
15 - 25 minutes
Modérée
If your camera is not quite functioning correctly, it may be the processor has become faulty. We'll show you how to fix it.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SX600 HS Main Board Processor Replacement, Battery: étape 1, image 1 de 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 2, image 1 de 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 3, image 1 de 2 Canon PowerShot SX600 HS Main Board Processor Replacement: étape 3, image 2 de 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Main Board Processor Replacement, Power and Shutter Buttons: étape 4, image 1 de 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 5, image 1 de 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 7, image 1 de 2 Canon PowerShot SX600 HS Main Board Processor Replacement: étape 7, image 2 de 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 8, image 1 de 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Main Board Processor Replacement, Display Screen: étape 9, image 1 de 2 Canon PowerShot SX600 HS Main Board Processor Replacement, Display Screen: étape 9, image 2 de 2
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 10, image 1 de 1
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 12, image 1 de 1
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 13, image 1 de 1
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
  14. Canon PowerShot SX600 HS Main Board Processor Replacement, Flash Assembly: étape 14, image 1 de 1
    • Unplug the assembly from the main no-fuss connector.
  15. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 15, image 1 de 1
    • Unplug the assembly from its flat-top connection.
  16. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 16, image 1 de 1
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
  17. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 17, image 1 de 1
    • Gently lift the assembly out of its place.
  18. Canon PowerShot SX600 HS Main Board Processor Replacement, Lens Piece: étape 18, image 1 de 1
    • Remove the 4 remaining 4mm screws in the frame with a Phillips #000 screwdriver.
  19. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 19, image 1 de 2 Canon PowerShot SX600 HS Main Board Processor Replacement: étape 19, image 2 de 2
    • Gently remove the frame. (Make sure to have a firm hold on the rest of the camera at this point)
    • The camera will be loose after this point. Be sure to have a firm hold on it.
  20. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 20, image 1 de 1
    • Unplug the ZIF connection between the lens to the main processor.
  21. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 21, image 1 de 1
    • Detach the flat-top connection.
  22. Canon PowerShot SX600 HS Main Board Processor Replacement, Main Board Processor: étape 22, image 1 de 1
    • Unplug the ZIF connection on the processor.
  23. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 23, image 1 de 1
    • Use a Phillips #000 screwdriver to unscrew the 2mm screw from the processor.
  24. Canon PowerShot SX600 HS Main Board Processor Replacement: étape 24, image 1 de 1
    • Use a plastic opening tool to gently lift the processor out of the holder.
Scott Childress
Membre depuis le 02/15/17
752 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S6-G4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 membres
9 tutoriels rédigés
1 commentaire de tutoriel
Note re Step 13: the cable has a 'click' type lock (you can see it as a narrow brown plastic strip on Step 12 and 13 pics). This lock can just about be disengaged with care before extracting the cable, I didn't, I just released it with tweezers as shown, and it didn't cause a problem. However, reversing Step 11 is very very difficult and you MUST have the click lock thing open before you begin (it's easy to see and understand when the switch plate is off , look at Step 12). You can then (just about!) re-insert the cable, and through a hole in the metal frame, just kind of below where the shutter button lies, flip the lock back down to hold the cable (use a tiny screwdriver or similar). It took me an hour to get the cable back in...so good luck with this part!
Tony J - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 18
Total : 653
