Aller au contenu principal
Canon Powershot SD790 IS LCD Screen Replacement
Gabriela
Gabriela et 14 autres contributeurs
Dernière mise à jour le May 7, 2024
30 - 40 minutes
Modérée
Étapes manquantes
Use this guide to remove and replace a broken LCD screen for a Canon PowerShot SD790 IS camera.
The LCD screen is a monitor that allows you to view pictures you have taken. If your screen has black spots or blurred areas, visible scratches or crack lines, or there is a lack of touch sensitivity, this could mean your screen is defective or broken.
No special skills required to perform this repair. Make sure to power off the camera and remove it from the charger before beginning.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: étape 1, image 1 de 3 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: étape 1, image 2 de 3 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: étape 1, image 3 de 3
    • Remove the two screws from the left side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the right side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Canon Powershot SD790 IS LCD Screen Replacement: étape 2, image 1 de 2 Canon Powershot SD790 IS LCD Screen Replacement: étape 2, image 2 de 2
    • Using your fingers, manually open the USB cover, labeled as “A/V OUT DIGITAL.”
    • Gently pull the tab of the side cover, completely detaching the cover from the camera.
  3. Canon Powershot SD790 IS LCD Screen Replacement: étape 3, image 1 de 3 Canon Powershot SD790 IS LCD Screen Replacement: étape 3, image 2 de 3 Canon Powershot SD790 IS LCD Screen Replacement: étape 3, image 3 de 3
    • Gently grab the sides of the camera and pry off the screen cover using your fingers.
    • If necessary, use a spudger.
    • Once the screen cover is removed, the front cover and side plate will slide off.
  4. Canon Powershot SD790 IS LCD Screen Replacement: étape 4, image 1 de 2 Canon Powershot SD790 IS LCD Screen Replacement: étape 4, image 2 de 2
    • Remove the screw located below the button release panel.
  5. Canon Powershot SD790 IS LCD Screen Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Using tweezers, gently slide the LCD cable, horizontally from its white plug towards the camera screen.
  6. Canon Powershot SD790 IS LCD Screen Replacement: étape 6, image 1 de 1
    • Caution: Do not completely remove the button release panel from the camera. The black and red cables will keep the panel attached to the camera. Allow the panel to hang out of the way as you complete the remaining steps.
    • Using your fingers, open the USB port cover (labeled as “A/V OUT DIGITAL” on the camera).
    • Using your fingers, remove the button release panel located on the top of the camera and allow room for it to hang out of the way.
  7. Canon Powershot SD790 IS LCD Screen Replacement: étape 7, image 1 de 2 Canon Powershot SD790 IS LCD Screen Replacement: étape 7, image 2 de 2
    • Using the spudger, flip the clip in an upward motion. The clip should remain attached to camera, not removed completely.
  8. Canon Powershot SD790 IS LCD Screen Replacement: étape 8, image 1 de 1
    • Using tweezers, gently slide the orange, translucent LCD ribbon from its dark gray plug horizontally towards the screen.
    • Remove the screen from the camera, and attach the new screen.
2 autres ont terminé cette réparation.
Gabriela
Membre depuis le 01/11/11
141 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-33, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 membres
5 tutoriels rédigés
Un commentaire
do I just put everyhting back together in the backwards order of how I took it off?
zion saez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 20
Total : 3,944
