Aller au contenu principal
Canon Powershot SD880 LCD Display Replacement
Ben Tupas
Ben Tupas et 8 autres contributeurs
Dernière mise à jour le December 21, 2022
5 minutes
Facile
Photos d’action
Étapes manquantes
The LCD display can be removed and replaced if it is cracked or broken.
Ce dont vous avez besoin
Outils
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 1 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 2 de 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 1 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 2 de 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: étape 2, image 3 de 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Ben Tupas
Membre depuis le 01/13/11
329 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
1 commentaire de tutoriel
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 2,404
