Aller au contenu principal
Canon Powershot SX500 IS LCD Screen Replacement
Marty Woolf
Marty Woolf et 3 autres contributeurs
Dernière mise à jour le June 24, 2015
10 minutes
Modérée
In order to replace the LCD screen you will need a PH00 screwdriver and a spudger. Be careful with the connections to the board it is easy to break.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. Canon Powershot SX500 IS LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS LCD Screen Replacement: étape 2, image 1 de 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS LCD Screen Replacement: étape 3, image 1 de 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: étape 4, image 1 de 3 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: étape 4, image 2 de 3 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: étape 4, image 3 de 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS LCD Screen Replacement: étape 5, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS LCD Screen Replacement: étape 6, image 1 de 1
  7. Canon Powershot SX500 IS LCD Screen Replacement: étape 7, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS LCD Screen Replacement: étape 8, image 1 de 2 Canon Powershot SX500 IS LCD Screen Replacement: étape 8, image 2 de 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS LCD Screen Replacement, Control Dial: étape 9, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS LCD Screen Replacement: étape 10, image 1 de 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS LCD Screen Replacement: étape 11, image 1 de 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS LCD Screen Replacement: étape 12, image 1 de 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS LCD Screen Replacement, LCD Screen: étape 13, image 1 de 1
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
2 autres ont terminé cette réparation.
Marty Woolf
Membre depuis le 04/07/15
173 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
Hello, my LCD screen is not working. One day it was fine, the next day I powered my camera and the LCD screen is only half visible. I appreciate the directions on how to take out/repair LCD screen, though where am I able to purchase a new LCD screen for my PowerShot SX500IS? Many thanks.
dana karavias - Réponse
Disassembly of SX510HS is exactly the same. No special pry tool is required - it is very easy to remove the cover with your fingernail. Replacement LCD on Aliexpress is 8-12 USD.
Witold Kardyś - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 1,219
