Aller au contenu principal
Canon SX40 HS Camera Battery Door Contact Replacement
John Bui
John Bui et 8 autres contributeurs
Dernière mise à jour le December 18, 2023
5 - 10 minutes
Modérée
Images incohérentes
This guide is for the replacement of the battery door contact in the Canon SX40 HS Camera (Model name 5251B001). In this guide you will be walked through the steps of removing and replacing the faulty battery door contact with a fresh one.
Battery contacts, also known as battery springs or contact springs, are strips of metal (usually with springs attached) that are placed inside of the battery compartment and assist with maintaining a constant electrical connection between the powered device and the battery's terminals. If your device will not power on, randomly powers off, or displays the screen and lights dimmer than they should be, you may have a faulty battery door contact. Ensure power to the device is properly disconnected before you begin the procedure.
For instructions on how to disconnect power, see here.
For instructions on what to do if the device's batteries are swollen, see here.
Ce dont vous avez besoin
Outils
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: étape 1, image 1 de 1
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: étape 2, image 1 de 1
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: étape 3, image 1 de 1
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: étape 4, image 1 de 1
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: étape 5, image 1 de 1
    • Replace either the internal metal battery contact or external battery compartment cover.
John Bui
Membre depuis le 03/26/15
352 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-7, Cichon Spring 2015 Membre de l'équipe UMass Dartmouth, Team 7-7, Cichon Spring 2015
UMASSD-CICHON-S15S7G7
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 916
