Aller au contenu principal
Capresso PerfecTea 260 Dial Replacement
Olivia Morgan
Olivia Morgan et 2 autres contributeurs
Dernière mise à jour le June 24, 2015
30 - 45 minutes
Modérée
Images incohérentes
If you have a broken or loose dial, then this guide can help you replace it.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Capresso PerfecTea 260 Dial Replacement, Motherboard: étape 1, image 1 de 1
    • First, take the base of the device and flip it over.
  2. Capresso PerfecTea 260 Dial Replacement: étape 2, image 1 de 2 Capresso PerfecTea 260 Dial Replacement: étape 2, image 2 de 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso PerfecTea 260 Dial Replacement: étape 3, image 1 de 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso PerfecTea 260 Dial Replacement: étape 4, image 1 de 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso PerfecTea 260 Dial Replacement: étape 5, image 1 de 2 Capresso PerfecTea 260 Dial Replacement: étape 5, image 2 de 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso PerfecTea 260 Dial Replacement: étape 6, image 1 de 1
    • Lift the motherboard out of the device
  7. Capresso PerfecTea 260 Dial Replacement, Control System: étape 7, image 1 de 2 Capresso PerfecTea 260 Dial Replacement, Control System: étape 7, image 2 de 2
    • Remove the two 7.5mm Phillips #2 screws from the metal frame.
    • Remove the frame from the assembly.
  8. Capresso PerfecTea 260 Dial Replacement: étape 8, image 1 de 3 Capresso PerfecTea 260 Dial Replacement: étape 8, image 2 de 3 Capresso PerfecTea 260 Dial Replacement: étape 8, image 3 de 3
    • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
    • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
  9. Capresso PerfecTea 260 Dial Replacement: étape 9, image 1 de 3 Capresso PerfecTea 260 Dial Replacement: étape 9, image 2 de 3 Capresso PerfecTea 260 Dial Replacement: étape 9, image 3 de 3
    • Find the cable that attaches the small computer chip to the heating element connections.
    • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
    • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
    • Push the latch off the tab with the spudger.
    • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
  10. Capresso PerfecTea 260 Dial Replacement: étape 10, image 1 de 3 Capresso PerfecTea 260 Dial Replacement: étape 10, image 2 de 3 Capresso PerfecTea 260 Dial Replacement: étape 10, image 3 de 3
    • Identify the two computer chips that connect the two yellow wires to the temperature controls.
    • Remove the four 5 mm Phillips #1 screws.
    • Remove the two computer chips from their places.
    • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
  11. Capresso PerfecTea 260 Dial Replacement: étape 11, image 1 de 3 Capresso PerfecTea 260 Dial Replacement: étape 11, image 2 de 3 Capresso PerfecTea 260 Dial Replacement: étape 11, image 3 de 3
    • Find the computer chip over the dial.
    • Remove the three 6mm Phillips #2 screws.
    • Remove the computer chip.
    • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
    • Keep the plastic frame on the bottom of the chip attached.
  12. Capresso PerfecTea 260 Dial Replacement: étape 12, image 1 de 1
    • Unplug the four cables on the left side of the chip.
    • Remember which cable goes to which plug.
  13. Capresso PerfecTea 260 Dial Replacement, Dial: étape 13, image 1 de 3 Capresso PerfecTea 260 Dial Replacement, Dial: étape 13, image 2 de 3 Capresso PerfecTea 260 Dial Replacement, Dial: étape 13, image 3 de 3
    • Remove the two 6 mm Phillips #1 screws from the black dial base plate.
    • 6 mm Phillips #1 screws
    • Remove the black dial base plate, metal spring, LED tube, and the actual dial.
  14. Capresso PerfecTea 260 Dial Replacement: étape 14, image 1 de 2 Capresso PerfecTea 260 Dial Replacement: étape 14, image 2 de 2
    • Remove the three 7.5 mm Phillips #2 screws from the dial collar.
    • 7.5 mm Phillips #2 screws
    • The dial collar will then come away from the base.
Olivia Morgan
Membre depuis le 04/14/15
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-17, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 215
