Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Capresso Perfectea 260 Control System Replacement
Ce dont vous avez besoin
  1. Capresso Perfectea 260 Control System Replacement, Motherboard: étape 1, image 1 de 1
    • First, take the base of the device and flip it over.
    Demander à FixBot
    Ajouter un commentaire
  2. Capresso Perfectea 260 Control System Replacement: étape 2, image 1 de 2 Capresso Perfectea 260 Control System Replacement: étape 2, image 2 de 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
    Demander à FixBot
  3. Capresso Perfectea 260 Control System Replacement: étape 3, image 1 de 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
    Demander à FixBot
  4. Capresso Perfectea 260 Control System Replacement: étape 4, image 1 de 1
    • Unplug the wire going into the side of the motherboard
    Demander à FixBot
  5. Capresso Perfectea 260 Control System Replacement: étape 5, image 1 de 2 Capresso Perfectea 260 Control System Replacement: étape 5, image 2 de 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
    Demander à FixBot
  6. Capresso Perfectea 260 Control System Replacement: étape 6, image 1 de 1
    • Lift the motherboard out of the device
    Demander à FixBot
  7. Capresso Perfectea 260 Control System Replacement, Control System: étape 7, image 1 de 2 Capresso Perfectea 260 Control System Replacement, Control System: étape 7, image 2 de 2
    • Remove the two 7.5mm Phillips #2 screws from the metal frame.
    • Remove the frame from the assembly.
    Demander à FixBot
  8. Capresso Perfectea 260 Control System Replacement: étape 8, image 1 de 3 Capresso Perfectea 260 Control System Replacement: étape 8, image 2 de 3 Capresso Perfectea 260 Control System Replacement: étape 8, image 3 de 3
    • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
    • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
    Demander à FixBot
  9. Capresso Perfectea 260 Control System Replacement: étape 9, image 1 de 3 Capresso Perfectea 260 Control System Replacement: étape 9, image 2 de 3 Capresso Perfectea 260 Control System Replacement: étape 9, image 3 de 3
    • Find the cable that attaches the small computer chip to the heating element connections.
    • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
    • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
    • Push the latch off the tab with the spudger.
    • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
    Demander à FixBot
  10. Capresso Perfectea 260 Control System Replacement: étape 10, image 1 de 3 Capresso Perfectea 260 Control System Replacement: étape 10, image 2 de 3 Capresso Perfectea 260 Control System Replacement: étape 10, image 3 de 3
    • Identify the two computer chips that connect the two yellow wires to the temperature controls.
    • Remove the four 5 mm Phillips #1 screws.
    • Remove the two computer chips from their places.
    • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
    Demander à FixBot
  11. Capresso Perfectea 260 Control System Replacement: étape 11, image 1 de 3 Capresso Perfectea 260 Control System Replacement: étape 11, image 2 de 3 Capresso Perfectea 260 Control System Replacement: étape 11, image 3 de 3
    • Find the computer chip over the dial.
    • Remove the three 6mm Phillips #2 screws.
    • Remove the computer chip.
    • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
    • Keep the plastic frame on the bottom of the chip attached.
    Demander à FixBot
  12. Capresso Perfectea 260 Control System Replacement: étape 12, image 1 de 1
    • Unplug the four cables on the left side of the chip.
    • Remember which cable goes to which plug.
    Demander à FixBot
Kenji Anzai
Membre depuis le 04/14/15
594 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-17, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 39
Total : 2,910
