Aller au contenu principal
Casio G’zOne Commando 4G LTE Volume Buttons Replacement
Brett Boehm
Brett Boehm et 3 autres contributeurs
Dernière mise à jour le July 26, 2024
20 minutes
Facile
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: étape 1, image 1 de 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: étape 1, image 2 de 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: étape 2, image 1 de 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: étape 2, image 2 de 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: étape 2, image 3 de 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove Side-Front cover: étape 3, image 1 de 1
    • Pull the side front cover off the face of the phone.
  4. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: étape 4, image 1 de 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: étape 4, image 2 de 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: étape 4, image 3 de 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: étape 5, image 1 de 1
    • Gently pull off the motherboard cover.
  6. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: étape 6, image 1 de 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: étape 7, image 1 de 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: étape 7, image 2 de 2
    • Gently remove the motherboard with the spudger.
  8. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: étape 8, image 1 de 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: étape 8, image 2 de 2
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing internal volume buttons: étape 9, image 1 de 1
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
Brett Boehm
Membre depuis le 09/25/14
281 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 162
