Aller au contenu principal
Ceiling Dome Light Fixture Replacement
Kier'n Harris
Kier'n Harris et 2 autres contributeurs
Dernière mise à jour le August 2, 2019
10 minutes
Modérée
Having problems with the ceiling dome light not turning on? This guide will help you fix the ceiling dome light, if the wiring is wrong.
  1. Ceiling Dome Light Fixture Replacement, Light Bulbs & Rewiring: étape 1, image 1 de 2 Ceiling Dome Light Fixture Replacement, Light Bulbs & Rewiring: étape 1, image 2 de 2
    • Turn the light off.
    • Leaving the power on could be dangerous.
  2. Ceiling Dome Light Fixture Replacement: étape 2, image 1 de 2 Ceiling Dome Light Fixture Replacement: étape 2, image 2 de 2
    • Twist the locking nut left to take it off.
    • You do not need any tools for this step.
    • The light cover is held together by the locking nut. Hold the light cover while twisting the locking nut, so that it will not drop to the ground and break.
  3. Ceiling Dome Light Fixture Replacement: étape 3, image 1 de 1
    • Pull the light cover down from the ceiling.
  4. Ceiling Dome Light Fixture Replacement: étape 4, image 1 de 1
    • Twist the light bulb out of it's socket.
  5. Ceiling Dome Light Fixture Replacement: étape 5, image 1 de 1
    • Lift the heat cover, also known as foil, out of the way.
  6. Ceiling Dome Light Fixture Replacement: étape 6, image 1 de 2 Ceiling Dome Light Fixture Replacement: étape 6, image 2 de 2
    • Unscrew the screws halfway.
    • Twist the base of the light fixture to take it off.
  7. Ceiling Dome Light Fixture Replacement: étape 7, image 1 de 1
    • There are three different colored wires. Black, white and copper. The black is the power wire, white is neutral and cooper is the ground wire.
    • Remove the black wire first, since it is the power. Then the white and copper wire.
  8. Ceiling Dome Light Fixture Replacement: étape 8, image 1 de 1
    • Once you have twisted the base of the light fixture, the base will come down.
    • It does not matter which colored wire you reassemble first.
    • Twist each wire from the base of the light fixture to the wire in the ceiling.
4 autres ont terminé cette réparation.
Kier'n Harris
Membre depuis le 07/02/18
277 Réputation
1 tutoriel rédigé
2 commentaires
Very helpful & easy to follow. Thanks!
drgf48 - Réponse
Awesome, now can I put a ceiling fan up their with bigger fasteners or do I need the whole setup? Thanks
galardopt - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 20
30 derniers jours : 40
Total : 20,657
