Aller au contenu principal
Cisco Meraki MC74-HW Phone Sensor Replacement
Anthony Kairouz
Anthony Kairouz et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 minutes
Modérée
If your Cisco Meraki MC74-HW does not detect that the phone is resting on its holder or does not automatically hang up, you may need to replace the phone sensor. Here are the steps to fix the problem with a simple change of the phone sensor. Once the back cover is fully detached from the device, a PH0 screw bit and reverse tweezers are needed to replace the phone sensor.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: étape 1, image 1 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: étape 1, image 2 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement, Back Housing and Device Stand: étape 1, image 3 de 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Phone Sensor Replacement: étape 2, image 1 de 2 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 2, image 2 de 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Phone Sensor Replacement: étape 3, image 1 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 3, image 2 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 3, image 3 de 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Phone Sensor Replacement: étape 4, image 1 de 2 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 4, image 2 de 2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: étape 5, image 1 de 2 Cisco Meraki MC74-HW Phone Sensor Replacement, Phone Sensor: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Phone Sensor Replacement: étape 6, image 1 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 6, image 2 de 3 Cisco Meraki MC74-HW Phone Sensor Replacement: étape 6, image 3 de 3
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
Anthony Kairouz
Membre depuis le 10/18/21
253 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Membre de l'équipe UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 175
