Aller au contenu principal
Classique 087CQA Heating Element Replacement
Brandon Jestis
Brandon Jestis et 4 autres contributeurs
Dernière mise à jour le September 14, 2024
10 - 15 minutes
Facile
A defective heating element can prevent the hair dryer from heating blown air, so we are replacing the heating element. Replacing the heating element should ensure hot air when blown.
Ce dont vous avez besoin
Outils
  1. Classique 087CQA Heating Element Replacement, Heating Element: étape 1, image 1 de 1
    • Begin with the side with switches
  2. Classique 087CQA Heating Element Replacement: étape 2, image 1 de 2 Classique 087CQA Heating Element Replacement: étape 2, image 2 de 2
    • Remove the Phillips PH0 bit
    • Insert the bit into the screwdriver
  3. Classique 087CQA Heating Element Replacement: étape 3, image 1 de 1
    • Unscrew the shell screw (1) with the screw driver
    • 5mm Phillips flat-head screw
  4. Classique 087CQA Heating Element Replacement: étape 4, image 1 de 1
    • Flip the hair dryer over to the side without switches
  5. Classique 087CQA Heating Element Replacement: étape 5, image 1 de 1
    • Unscrew the shell screw (1) with the screwdriver
  6. Classique 087CQA Heating Element Replacement: étape 6, image 1 de 2 Classique 087CQA Heating Element Replacement: étape 6, image 2 de 2
    • Remove the bit from the screwdriver and insert the Phillips PH2 bit
  7. Classique 087CQA Heating Element Replacement: étape 7, image 1 de 1
    • Unscrew the remaining shell screws (5) with the screwdriver
    • 15mm Phillips round-head screws
  8. Classique 087CQA Heating Element Replacement: étape 8, image 1 de 2 Classique 087CQA Heating Element Replacement: étape 8, image 2 de 2
    • Gently pull the two sides apart
    • Separate each side
  9. Classique 087CQA Heating Element Replacement: étape 9, image 1 de 1
    • Remove front grill
  10. Classique 087CQA Heating Element Replacement: étape 10, image 1 de 2 Classique 087CQA Heating Element Replacement: étape 10, image 2 de 2
    • Pull up and remove the heating element assembly
  11. Classique 087CQA Heating Element Replacement: étape 11, image 1 de 1
    • Remove the outer sleeve and replace the heating element
Brandon Jestis
Membre depuis le 01/31/17
1 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 25
Total : 743
