Compaq Mini 110 Display Assembly Replacement
Introduction
Passez à l'étape 1Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Ce dont vous avez besoin
Outils
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the four screws that keep the bottom of the hinges attached to the base.
5 autres ont terminé cette réparation.
