Aller au contenu principal
Cosori Pro II Motherboard Replacement
Andrew Levonius
Andrew Levonius et 3 autres contributeurs
Dernière mise à jour le January 3, 2025
7 minutes
Modérée
Nécessite plus d'images
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Cosori Pro II Motherboard Replacement, Shell: étape 1, image 1 de 1
    • Flip the device upside down and remove all of the Phillips #1 screws.
  2. Cosori Pro II Motherboard Replacement: étape 2, image 1 de 2 Cosori Pro II Motherboard Replacement: étape 2, image 2 de 2
    • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
    • Remove the panel.
  3. Cosori Pro II Motherboard Replacement: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove all four screws.
    • Lift off the bracket.
    • When lifting this off be careful to not unplug the screen.
  4. Cosori Pro II Motherboard Replacement: étape 4, image 1 de 2 Cosori Pro II Motherboard Replacement: étape 4, image 2 de 2
    • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
    • Dissemble the shell going up to separate the basket holder.
  5. Cosori Pro II Motherboard Replacement: étape 5, image 1 de 2 Cosori Pro II Motherboard Replacement: étape 5, image 2 de 2
    • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
    • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
  6. Cosori Pro II Motherboard Replacement: étape 6, image 1 de 2 Cosori Pro II Motherboard Replacement: étape 6, image 2 de 2
    • Pull the bottom shell down pulling at the sides to get them over screw holes.
  7. Cosori Pro II Motherboard Replacement, Motherboard: étape 7, image 1 de 2 Cosori Pro II Motherboard Replacement, Motherboard: étape 7, image 2 de 2
    • Depress the white clip and disconnect the screen connector.
  8. Cosori Pro II Motherboard Replacement: étape 8, image 1 de 2 Cosori Pro II Motherboard Replacement: étape 8, image 2 de 2
    • Remove the plastic panel.
  9. Cosori Pro II Motherboard Replacement: étape 9, image 1 de 1
    • Remove the two screws with a Phillips #1 screwdriver.
  10. Cosori Pro II Motherboard Replacement: étape 10, image 1 de 3 Cosori Pro II Motherboard Replacement: étape 10, image 2 de 3 Cosori Pro II Motherboard Replacement: étape 10, image 3 de 3
    • Apply force simultaneously to the four hooks to release the mother board.
    • Using a prying tool pull out the springs on the mother board from their sockets.
    • Remove the motherboard.
Andrew Levonius
Membre depuis le 08/28/24
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 25
Total : 119
