Aller au contenu principal
Craig CMP801 Volume Controls Replacement
Mohammed
Mohammed et 3 autres contributeurs
Dernière mise à jour le May 16, 2024
4 minutes
Facile
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Craig CMP801 Volume Controls Replacement, Back Cover: étape 1, image 1 de 2 Craig CMP801 Volume Controls Replacement, Back Cover: étape 1, image 2 de 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Volume Controls Replacement: étape 2, image 1 de 2 Craig CMP801 Volume Controls Replacement: étape 2, image 2 de 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Volume Controls Replacement: étape 3, image 1 de 2 Craig CMP801 Volume Controls Replacement: étape 3, image 2 de 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Volume Controls Replacement, Volume Controls: étape 4, image 1 de 2 Craig CMP801 Volume Controls Replacement, Volume Controls: étape 4, image 2 de 2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 Volume Controls Replacement: étape 5, image 1 de 2 Craig CMP801 Volume Controls Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 Volume Controls Replacement: étape 6, image 1 de 2 Craig CMP801 Volume Controls Replacement: étape 6, image 2 de 2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
Mohammed
Membre depuis le 09/25/17
150 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 8
Total : 323
