Aller au contenu principal
Cuisinart CPT-140BK  Circuit Board Replacement
Liya Zulfiquar
Liya Zulfiquar et 4 autres contributeurs
Dernière mise à jour le July 26, 2024
20 minutes
Modérée
This guide will explain how to replace Cuisinart CPT-140BK toaster circuit board. It instructs through the process of disassembly to prevent damage on display cables and panels.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Cuisinart CPT-140BK  Circuit Board Replacement, Circuit Board: étape 1, image 1 de 1
    • Unplug the toaster before disassembly.
  2. Cuisinart CPT-140BK  Circuit Board Replacement: étape 2, image 1 de 2 Cuisinart CPT-140BK  Circuit Board Replacement: étape 2, image 2 de 2
    • Turn the toaster upside down.
    • Unscrew all 4mm screws using Phillips #2 screwdriver.
  3. Cuisinart CPT-140BK  Circuit Board Replacement: étape 3, image 1 de 1
    • Turn the toaster right side up.
    • Lift up the front cover carefully because the cables can be damaged.
    • Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
  4. Cuisinart CPT-140BK  Circuit Board Replacement: étape 4, image 1 de 3 Cuisinart CPT-140BK  Circuit Board Replacement: étape 4, image 2 de 3 Cuisinart CPT-140BK  Circuit Board Replacement: étape 4, image 3 de 3
    • Detach the cable that connects the toaster to the circuit board, in both control panels.
  5. Cuisinart CPT-140BK  Circuit Board Replacement: étape 5, image 1 de 1
    • Carefully lift up the top cover.
  6. Cuisinart CPT-140BK  Circuit Board Replacement: étape 6, image 1 de 3 Cuisinart CPT-140BK  Circuit Board Replacement: étape 6, image 2 de 3 Cuisinart CPT-140BK  Circuit Board Replacement: étape 6, image 3 de 3
    • The circuit board is located inside the front cover.
    • Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
    • Remove and replace the circuit board.
Liya Zulfiquar
Membre depuis le 09/20/17
246 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 571
