Curtain Rod Bracket Replacement
Introduction
Passez à l'étape 1If your curtain rod bracket has been ripped out of the wall, use this guide to securely reattach the bracket to the wall.
It is common for a curtain rod bracket to come apart from the wall as a result of accidental tension. A broken bracket may leave you without curtains that provide you privacy in your home.
Before using this guide, confirm that the screws have been stripped from the wall and cannot be screwed directly back in without further action. Otherwise, the bracket can be screwed in without additional steps.
Before beginning, confirm that all screws, drill bits, and anchors are the same size as your bracket to avoid any mistakes.
Caution: Step three requires you to use a cordless drill to drill a hole in the wall. Remember to keep your hands and hair away from the electric drill at all times.
Ce dont vous avez besoin
Outils
Afficher plus…
If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
Enjoy your renewed privacy!
