Aller au contenu principal
DJI Mavic Pro GPS Module Replacement
Kyle Kelser
Kyle Kelser et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
15 minutes
Facile
Tutoriel étudiant vedette
This set of instructions will walk you through the removal process of the DJI Mavic Pro GPS Module. You will first need to remove the battery and then the upper shell before you can get to the GPS Module. Be aware when going through the removal of the module that you may hear a popping sound; don't be alarmed as this is normal.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. DJI Mavic Pro GPS Module Replacement, Battery: étape 1, image 1 de 3 DJI Mavic Pro GPS Module Replacement, Battery: étape 1, image 2 de 3 DJI Mavic Pro GPS Module Replacement, Battery: étape 1, image 3 de 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: étape 2, image 1 de 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: étape 3, image 1 de 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: étape 5, image 1 de 1
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: étape 6, image 1 de 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: étape 7, image 1 de 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: étape 8, image 1 de 1
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: étape 9, image 1 de 1
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: étape 10, image 1 de 1
    • Use tweezers to remove the GPS Module from the upper shell.
8 autres ont terminé cette réparation.
Kyle Kelser
Membre depuis le 10/08/18
610 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G3, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 85
Total : 9,330
