Aller au contenu principal
DOSS SoundBox Base-plate Replacement
Brendan Harkreader
Brendan Harkreader et 4 autres contributeurs
Dernière mise à jour le January 10, 2025
5 - 15 minutes
Facile
This guide will help you replace or remove the base plate on your DOSS SoundBox portable Bluetooth speaker, which provides structural integrity and protects the device's internal components. The base plate may need replacement if your speaker shows signs of physical instability or sound distortion coming from the base of the speaker. Before starting, ensure the device is powered off to avoid accidental damage.
Ce dont vous avez besoin
  1. DOSS SoundBox Base-plate Replacement, Base-plate: étape 1, image 1 de 3 DOSS SoundBox Base-plate Replacement, Base-plate: étape 1, image 2 de 3 DOSS SoundBox Base-plate Replacement, Base-plate: étape 1, image 3 de 3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: étape 2, image 1 de 1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: étape 3, image 1 de 1
    • Lift the base-plate off of the enclosure.
3 autres ont terminé cette réparation.
Brendan Harkreader
Membre depuis le 09/27/18
538 Réputation
3 tutoriels rédigés
1 commentaire de tutoriel
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 18
Total : 2,163
