Aller au contenu principal
DROCON Ninja Casing Replacement
Taylor Ullmann
Taylor Ullmann et 4 autres contributeurs
Dernière mise à jour le May 27, 2020
25 - 30 minutes
Modérée
This guide will help you replace the casing on the DROCON Ninja DC-014. The carbon fiber casing provides support to the drone during flight. The casing might need to be replaced if the power button isn’t functioning or the frame is cracked. For this guide, you will need a Phillips 00 screwdriver and an opening tool. There are no difficult steps required for this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. DROCON Ninja Casing Replacement, Battery: étape 1, image 1 de 3 DROCON Ninja Casing Replacement, Battery: étape 1, image 2 de 3 DROCON Ninja Casing Replacement, Battery: étape 1, image 3 de 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: étape 2, image 1 de 3 DROCON Ninja Casing Replacement, Casing: étape 2, image 2 de 3 DROCON Ninja Casing Replacement, Casing: étape 2, image 3 de 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: étape 3, image 1 de 2 DROCON Ninja Casing Replacement: étape 3, image 2 de 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: étape 4, image 1 de 3 DROCON Ninja Casing Replacement: étape 4, image 2 de 3 DROCON Ninja Casing Replacement: étape 4, image 3 de 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 8
Total : 176
