Aller au contenu principal
Dell   Inspiron  15-7569 Battery Replacement
Matthew Clements
Matthew Clements et 5 autres contributeurs
Dernière mise à jour le February 6, 2023
10 - 30 minutes
Facile
Nécessite plus d'images
If your computer has to remain on the charger to be used or is not holding a battery charge like it used to, this guide will help you replace your battery.
Ce dont vous avez besoin
Kit de réparation
Ce kit contient toutes les pièces et tous les outils nécessaires à la réalisation de ce tutoriel.
Pièces
Outils
Afficher plus…
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: étape 2, image 3 de 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
5 autres ont terminé cette réparation.
Matthew Clements
Membre depuis le 10/03/17
546 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 membres
6 tutoriels rédigés
Un commentaire
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 22
Total : 6,535
