Aller au contenu principal
Dell Chromebook 3100 Battery Replacement
Jon
Jon et 4 autres contributeurs
Dernière mise à jour le December 2, 2024
25 secondes - 1 minute
Facile
Police de grammaire
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: étape 1, image 1 de 2 Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: étape 1, image 2 de 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
  2. Dell Chromebook 3100 Battery Replacement, #1 - Remove Battery Screws: étape 2, image 1 de 1
    • Remove the 3 battery screws with a Phillips #0 screwdriver.
    • Temporarily disconnect the sticker on the bottom left corner of the battery. You will need to reconnect this sticker when installing the new battery.
    • Lift the battery out of the palm rest. You may feel some resistance while trying to remove the battery. There is a piece of double-sided tape underneath the battery in the top left corner. (See video)
    • Disconnect the motherboard battery cable from the top of the battery.
Jon
Membre depuis le 08/18/13
3 921 Réputation
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 56
Total : 1,313
