Aller au contenu principal
Dell Chromebook 3110 Speakers Replacement
Kyle Neblo
Kyle Neblo et un autre contributeur
Dernière mise à jour le May 24, 2023
1 minute
Facile
The speakers in the Dell Chromebook 3110 are very loosely fastened, and easy to remove once the battery is no longer in the device. No special tools are required for this replacement, but tweezers may be helpful when working in tight spaces.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Chromebook 3110 Speakers Replacement, Battery: étape 1, image 1 de 1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Speakers Replacement: étape 2, image 1 de 1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Speakers Replacement: étape 3, image 1 de 1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Speakers Replacement: étape 4, image 1 de 1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Speakers Replacement: étape 5, image 1 de 1
    • Carefully lift the battery out of the laptop.
  6. Dell Chromebook 3110 Speakers Replacement, Speakers: étape 6, image 1 de 1
    • Remove adhesive tape securing the speaker cable to the motherboard, and disconnect the speaker cable from the motherboard.
  7. Dell Chromebook 3110 Speakers Replacement: étape 7, image 1 de 1
    • Carefully remove the speaker cable from the retention clips towards the bottom of the device.
  8. Dell Chromebook 3110 Speakers Replacement: étape 8, image 1 de 1
    • Lift and remove the speakers from the device.
Kyle Neblo
Membre depuis le 02/24/23
177 Réputation
1 tutoriel rédigé
Équipe
Marist, Team 1-6, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 189
