Aller au contenu principal
Dell Inspirion 15z-5523 Battery Replacement
Christian Chavez
Christian Chavez et 5 autres contributeurs
Dernière mise à jour le July 20, 2020
10 minutes
Facile
Outils incorrects
This tutorial covers the process of replacing a Dell Inspiron 15z-5523 battery.  As with all batteries after multiple charging and discharging cycles, the battery will eventually begin to lose the ability to hold a charge.  The older the battery the more likely they are to begin to show this performance deterioration.
Ce dont vous avez besoin
Outils
  1. Dell Inspirion 15z-5523 Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove all rubber stoppers and screw from the back of the laptop
  2. Dell Inspirion 15z-5523 Battery Replacement: étape 2, image 1 de 2 Dell Inspirion 15z-5523 Battery Replacement: étape 2, image 2 de 2
    • Detach keyboard from the laptop
    • Unscrew 4 screws on the metal frame (yellow circles)
    • Disconnect the 4 data connections (teal arrows)
  3. Dell Inspirion 15z-5523 Battery Replacement: étape 3, image 1 de 1
    • Remove top computer frame
  4. Dell Inspirion 15z-5523 Battery Replacement: étape 4, image 1 de 2 Dell Inspirion 15z-5523 Battery Replacement: étape 4, image 2 de 2
    • Remove the 5 screws that holding the old battery
    • Gently lift up battery and pull it out
Christian Chavez
Membre depuis le 01/23/18
729 Réputation
5 tutoriels rédigés
2 commentaires
Excellent, Easy to follow and helpful graphics. Thanks
leonard russ - Réponse
Hi Christian,
Would you happen to know what are the specs for the seven screws in the base of the Inspiron 15z 5523? Mine is exactly like the one in your post for replacing the battery. I lost mine when replacing the fan. Dell won’t help because the machine is out of warranty. Any ideas would be appreciated.
Thanks Christian.
David
David Sokal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 28
Total : 3,683
