Aller au contenu principal
Dell Inspiron 11 i3147 Battery Replacement
Muhammad Erchid
Muhammad Erchid et 4 autres contributeurs
Dernière mise à jour le February 27, 2020
5 - 10 minutes
Modérée
The Dell Inspiron 11 i3147 battery may be need to be replaced if it has lost its ability to hold a charge or does not fully charge. This guide will show you how to remove the old battery and replace it with a new one.
If your battery is swollen, it may be punctured. This is dangerous, so follow these precautions.
Make sure the device is turned off before you begin.
The old battery is considered a rechargeable battery, so dispose of it properly at your local recycling facility.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Dell Inspiron 11 i3147 Battery Replacement, Battery: étape 1, image 1 de 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Battery Replacement: étape 2, image 1 de 1
    • Remove the nine 7.6 mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Battery Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Battery Replacement: étape 4, image 1 de 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Battery Replacement: étape 5, image 1 de 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Battery Replacement: étape 6, image 1 de 1
    • Lift the battery from the computer.
    • Replace old battery with new one.
Muhammad Erchid
Membre depuis le 10/09/18
1 087 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 12
Total : 309
