Aller au contenu principal
Dell Inspiron 11-3164 Speaker Assembly Replacement
Michael Kendziora
Michael Kendziora et 3 autres contributeurs
Dernière mise à jour le July 14, 2019
10 - 25 minutes
Modérée
Meilleure introduction
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: étape 1, image 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: étape 1, image 2 de 2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: étape 2, image 2 de 2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: étape 3, image 1 de 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: étape 3, image 2 de 2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Michael Kendziora
Membre depuis le 02/14/18
781 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 10
Total : 164
