Aller au contenu principal
Dell Inspiron 11-3168 Wifi module Replacement
Matthew Roomsburg
Matthew Roomsburg et 4 autres contributeurs
Dernière mise à jour le March 24, 2021
30 minutes
Très difficile
This guide will show you how to replace the WiFi module on your Dell Inspiron 11-3168. Note: There is one small screw that may be difficult to grip with your fingers. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Dell Inspiron 11-3168 Wifi module Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 3 de 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Wifi module Replacement: étape 3, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement: étape 3, image 2 de 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Wifi module Replacement: étape 4, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement: étape 4, image 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 3 de 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 3 de 3
    • Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
  7. Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the screw that is holding the WiFi module in place.
    • Remove the metal piece that covers the antenna cable connectors.
  8. Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 3 de 3
    • To remove the WiFi module from the motherboard, slide it free of the socket connector.
  9. Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 3 de 3
    • Disconnect both the black and the white wires from the WiFi module.
To install the replacement module, start at step 4 and work your way backwards to step 1.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 15
Total : 561
