Aller au contenu principal
Dell Inspiron 11z 1120 Display Assembly Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 13, 2019
8 - 15 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Display Assembly.
Ce dont vous avez besoin
  1. Dell Inspiron 11z 1120 Display Assembly Replacement, Disconnecting the Antenna Cables: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z 1120 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 11z 1120 Display Assembly Replacement, Lifting the Display Assembly: étape 3, image 1 de 1
    • Lift and remove the display assembly off the computer base.
  4. Dell Inspiron 11z 1120 Display Assembly Replacement, Place the Display Assembly: étape 4, image 1 de 2 Dell Inspiron 11z 1120 Display Assembly Replacement, Place the Display Assembly: étape 4, image 2 de 2
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z 1120 Display Assembly Replacement, Connect the Display Cable: étape 5, image 1 de 1
    • Connect the display cable to the system board connector.
  6. Dell Inspiron 11z 1120 Display Assembly Replacement, Routing the Antenna Cables: étape 6, image 1 de 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  7. Dell Inspiron 11z 1120 Display Assembly Replacement, Connecting the Mini-Card Cables: étape 7, image 1 de 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 172
