Dell Inspiron 13 7378 Wi-Fi Card Replacement
Introduction
Passez à l'étape 1Does your Wi-Fi from your Dell Inspiron 13 7378 not connect to a network? This guide will help you walk through replacing your Wi-Fi card and get you back on the web.
The Wi-Fi card is the part of the laptop's way of connecting to a Wi-Fi network. The Wi-Fi card is a very small 1 inch square located on the motherboard which can easily be broken if the steps are not followed correctly.
Ce dont vous avez besoin
Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
