Aller au contenu principal
Dell Inspiron 13-5368 Heatsink Replacement
Matt Sugrim
Matt Sugrim et 3 autres contributeurs
Dernière mise à jour le September 11, 2023
10 - 15 minutes
Modérée
A besoin de meilleures images
This is a simple step-by-step guide on how to remove and replace a screen display for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This is a relatively easy task and will take about 8 minutes to complete.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 13-5368 Heatsink Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-5368 Heatsink Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-5368 Heatsink Replacement, Battery: étape 1, image 3 de 3
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Heatsink Replacement: étape 2, image 1 de 2 Dell Inspiron 13-5368 Heatsink Replacement: étape 2, image 2 de 2
    • Use a spudger / pry tool to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Heatsink Replacement: étape 3, image 1 de 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Heatsink Replacement: étape 4, image 1 de 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Heatsink Replacement: étape 5, image 1 de 2 Dell Inspiron 13-5368 Heatsink Replacement: étape 5, image 2 de 2
    • Lift the battery straight up out of the housing.
  6. Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: étape 6, image 1 de 2 Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: étape 6, image 2 de 2
    • Unscrew the four screws securing the heatsink and remove it.
    • Remember to reapply a small amount of thermal paste, then screw the heatsink onto the motherboard in numberical order (i.e. 1, 2, 3, 4).
Remember to clean off any old thermal paste, then apply a small amount of new thermal paste (dime size will be fine). Screw the heatsink on in numerical order so the thermal paste is evenly distributed on the processor. To reassemble your device, follow these instructions in reverse order.
Matt Sugrim
Membre depuis le 09/27/17
1 066 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 membres
13 tutoriels rédigés
Un commentaire
Is it normal for the heatsink to be loose right in front of the fan? The black part of the heatsink?
JRaje - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 29
Total : 738
