Aller au contenu principal
Dell Inspiron 13-5368 Touchpad Replacement
Matt Sugrim
Matt Sugrim et un autre contributeur
Dernière mise à jour le September 11, 2023
10 - 15 minutes
Modérée
A besoin de meilleures images
This is a simple step-by-step guide on how to remove and replace a touchpad for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. It is very easy to do and will take about 7 minutes.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13-5368 Touchpad Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-5368 Touchpad Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-5368 Touchpad Replacement, Battery: étape 1, image 3 de 3
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Touchpad Replacement: étape 2, image 1 de 2 Dell Inspiron 13-5368 Touchpad Replacement: étape 2, image 2 de 2
    • Use a spudger / pry tool to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Touchpad Replacement: étape 3, image 1 de 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Touchpad Replacement: étape 4, image 1 de 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Touchpad Replacement: étape 5, image 1 de 2 Dell Inspiron 13-5368 Touchpad Replacement: étape 5, image 2 de 2
    • Lift the battery straight up out of the housing.
  6. Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: étape 6, image 1 de 2 Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: étape 6, image 2 de 2
    • Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
  7. Dell Inspiron 13-5368 Touchpad Replacement: étape 7, image 1 de 1
    • Remove the 1.5mm Phillips #0 screws that hold the touchpad to the laptop case.
  8. Dell Inspiron 13-5368 Touchpad Replacement: étape 8, image 1 de 2 Dell Inspiron 13-5368 Touchpad Replacement: étape 8, image 2 de 2
    • Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
Matt Sugrim
Membre depuis le 09/27/17
1 066 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 49
Total : 3,722
