Aller au contenu principal
Dell Inspiron 13-7359 WLAN Adaptor Replacement
Bo Yi Lim
Bo Yi Lim et un autre contributeur
Dernière mise à jour le June 27, 2019
5 - 15 minutes
Facile
Use this guide to replace your WLAN adaptor. You will need a Phillips #0 screwdriver and a plastic opening tool to complete this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: étape 1, image 1 de 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 2, image 1 de 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 3, image 1 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 3, image 2 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 3, image 3 de 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 4, image 1 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 4, image 2 de 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 4, image 3 de 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: étape 5, image 1 de 1
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 6, image 1 de 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: étape 7, image 1 de 1
    • Gently remove the WLAN adaptor.
Bo Yi Lim
Membre depuis le 04/02/19
205 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 171
