Aller au contenu principal
Dell Inspiron 13-7370 Fan Replacement
Zayed Azam
Zayed Azam et un autre contributeur
Dernière mise à jour le June 30, 2021
20 - 35 minutes
Modérée
A besoin de meilleures images
Use this guide to replace a fan on your Dell Inspiron 7370 laptop.
A working fan allows your laptop to work at higher capacity, without having to worry about overheating its components. However, it may be necessary to remove the fan, either due to it not working anymore, or to clean the fan blades and allow air to pass through it again.
For this guide, you will need a Phillips #0 screwdriver. To take the laptop case apart, a plastic pick is recommended, although you can also use you fingers and a bit of elbow grease instead.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 1 de 3 Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 2 de 3 Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 3 de 3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 2, image 2 de 2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: étape 3, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 4, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: étape 5, image 1 de 3 Dell Inspiron 13-7370 Fan Replacement: étape 5, image 2 de 3 Dell Inspiron 13-7370 Fan Replacement: étape 5, image 3 de 3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: étape 6, image 1 de 1
    • Remove the fan from the device.
Zayed Azam
Membre depuis le 05/16/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G6, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S1-G6, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G6
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 875
